Enable this flag to support IPv6 routes with prefix-lengths greater than 64 bits.
This flag is disabled by default. Use this procedure to enable (set to true) the IPv6-mode boot config flag.
When the IPv6-mode boot config flag is enabled, the maximum number of IPv4 routing table entries decreases. For scaling information, see VOSS Release Notes.
    enable
    configure terminal
  2. Enable the IPv6-mode boot config flag:
    boot config flags ipv6-mode
  3. Save the configuration, and then reboot the switch for the change to the IPv6-mode boot config flag to take effect.
  4. After you reboot the switch, verify that the IPv6-mode boot config flag is set to true:
    show boot config flags
